| Outside door handle push button will not work? https://slantsix.org/forum/viewtopic.php?t=53339 |
| Author: | bmimken [ Mon Sep 16, 2013 9:20 am ] |
| Post subject: | Outside door handle push button will not work? |
On my 74 Duster which has 72 doors, the driver side outside handle push button has stopped working. The button will depress, but apparently does not unlatch the door. The inside door handle on the same door does operate the door latch. What should I start looking for? Brian |
| Author: | VDART [ Mon Sep 16, 2013 4:14 pm ] |
the rod that connects the pushbutton to the latch has came loose-- would be my first guess- check ,Lawrence |
| Author: | bmimken [ Mon Sep 16, 2013 4:59 pm ] |
Will do that first thing when I get back home next Monday. Thanks for the advice. I'm hoping it's a simple fix. Brian |
| Author: | DusterIdiot [ Wed Sep 18, 2013 10:34 am ] |
| Post subject: | Yep. |
Quote: the rod that connects the pushbutton to the latch has came loose
most likely the clip that holds the rod on the lever has broken and let the rod come loose (similar to the clip for the carburator choke pull off). This is a common problem of the late A-bodies along with the outside button getting stuck "pushed in" due to factory quality going down hill over the years...-D.Idiot |
| Author: | 75valiant [ Wed Sep 18, 2013 11:22 am ] |
yep. dorman sells the clips in the help! section... |
