| A Body Lower Control Arm Bushing Removal https://slantsix.org/forum/viewtopic.php?t=53346 |
| Author: | Greg Ondayko [ Mon Sep 16, 2013 12:46 pm ] |
| Post subject: | A Body Lower Control Arm Bushing Removal |
Hello, I was Just curious about lower control bushing removal. I was able to remove the stud from the center with the press. After removing the stud is there a correct way to get the rest of the bushing / Shell out? I just burned the rubber out with a torch and then took a die grinder and ground a line down on the inside of the outer sleeve until I had enough play to knock it out with a chisel. is there another way to do it? Just curious. PS.. pressing it back together was a breeze! Greg |
| Author: | Joshie225 [ Mon Sep 16, 2013 1:33 pm ] |
You've already come to one of the best methods going by grinding out part of the bushing shell. Some weld a washer to the shell so it can be pressed out. Of course this requires access to and use of a welder. |
| Author: | Greg Ondayko [ Mon Sep 16, 2013 1:36 pm ] |
thanks josh! I do have access to those.. Greg |
| Author: | Romeo Furio [ Tue Sep 17, 2013 7:33 pm ] |
If you are going with a poly bushing you need to leave the inner sleve attached to shaft. If not remove it the same way by cutting a few slots along the length with a cut off wheel/die grinder. |
| Author: | Greg Ondayko [ Wed Sep 18, 2013 9:36 am ] |
Thanks Romeo. This was with a standard bushing install. So No saving metal shells. Greg |
| Author: | SpaceFrank [ Fri Sep 27, 2013 3:38 am ] |
I welded a washer in when we did ours. We used the nylon bushings from Firmfeel, which apparently don't require saving the outer sleeve. |
| Author: | '67 Dart 270 [ Sun Dec 08, 2013 6:33 pm ] |
| Post subject: | LCA bushing removal |
Mopar Muscle has this tutorial: http://www.moparmusclemagazine.com/tech ... _bushings/ bg |
| Author: | wjajr [ Mon Dec 09, 2013 7:27 am ] |
Nice article and photos, best I have seen. This write up has been added to my Favorites Suspension folder along with a video showing how to take the slop out of a lower control arm; thanks. |
