Bypass the ballast how to...
https://slantsix.org/forum/viewtopic.php?t=53400
Author:  SlantedTrucker [ Mon Sep 23, 2013 5:00 am ]
Post subject:  Bypass the ballast how to...
I'm going to switch to a Pertronix 3ohm coil so I can bypass the ballast resister. My question is: what is the proper way to put these wires together?
This is a dual or 4 terminal resister.
Author:  Aggressive Ted [ Thu Sep 26, 2013 12:37 pm ]
Solder them!
Then use heat shrink over them.
Author:  SlantedTrucker [ Sat Sep 28, 2013 4:11 am ]
Thanks Ted, thats what I'll do.
Author:  josekh7 [ Thu Oct 10, 2013 5:39 pm ]
im doing the same thing to my ignitor 1 should i but any fuse or anything to protect the hotcoil?
Author:  carlherrnstein [ Fri Oct 11, 2013 6:13 am ]
That circuit already has a fuse in it.
Author:  Aggressive Ted [ Sat Oct 12, 2013 11:49 am ]
Do not put a fuse on the coil. That will cause lots of problems with poor voltage to the coil from the fuse glowing causing a huge drop in voltage.
Also many Ignitor 1 and 11's die from low voltage and lack of cooling.
