| Rod bolts https://slantsix.org/forum/viewtopic.php?t=53435 |
| Author: | kesteb [ Thu Sep 26, 2013 10:09 pm ] |
| Post subject: | Rod bolts |
Is it normal for the rod bolts to fall out of the rods on a 170? Just one of the mysteries of this block. First I though it was a 225 block, I was told that it was by person that I got it from and they are usually reliable. Then I noticed the crank didn't look quite right. Then I noticed the pistons were at the top of the bore when removing them. It also looks like it munched a distributor gear some time in the past. I have most of the parts for a short block. But what am I going to do with a 170... |
| Author: | Fopar [ Thu Sep 26, 2013 11:12 pm ] |
How long was the water pump to head hose? How long are the rods (center of small end to center of big end)? Richard |
| Author: | slantzilla [ Fri Sep 27, 2013 12:16 am ] |
To answer the original question, it is not unusual for rod bolts to fall out of stock, used rods, no matter what CID. |
