It is currently Wed May 06, 2026 12:56 am
 Post subject: Tails!
PostPosted: Tue Mar 18, 2003 7:22 pm
Would I have to change the long tailshaft/housing on my 727 (from a van) to the shorter passenger car shaft/housing for use in a car? Or just chop the driveshaft?
PostPosted: Wed Mar 19, 2003 2:51 pm
You can probably get away with just a shorter driveshaft, although the rear mount point might also be different. I would recommend staying with the 904 if at all possible - plenty durable and much lighter.
PostPosted: Wed Mar 19, 2003 6:39 pm
I can definitely tell the weight difference with the ol' bicep test, but does anyone have any rough idea of the weight difference?
PostPosted: Thu Mar 20, 2003 8:50 am
I've never noticed a shorter 727 tailshaft for cars. The ones I've seen are the same as 2WD trucks and vans. There is a short 727 tailshaft that was used on some older 4WD trucks. I had a '74 Powerwagon that used a short tailshaft and a short driveshaft to the transfer case. That was the last year for it's use in 1/2 ton Powerwagons, '75 used a full time 4WD with the tailshaft bolting to the transfer case. I think that's a different tialshaft than the '74 used.
Cecil
PostPosted: Thu Mar 20, 2003 5:08 pm
Ok, because I saw the tailhousing from my 727 and compared it to one from a 904, and I was like :shock:
PostPosted: Fri Mar 21, 2003 5:32 am
The A-bodies with 727 trannies did not have a shorter tail shaft to match the length of the 904 or manual trannies. They just used a shorter drive shaft.
FWIW, I am using the long tailshaft A833OD 4spd tranny in my 68 Barracuda. A shorter drive shaft and a little fabing for the shifter mount, otherwise it was a straight bolt in.
Dave Clement
68 Barracuda (Hot-Rod \6)
http://mysite.verizon.net/vze4pgxf/
PostPosted: Thu Apr 03, 2003 6:50 pm
Another tail-ish question...
Could you take a 4-wheel 727 and put the longer tailshaft, along with the tailhousing, and have a passenger car 727? I'm not too familiar with the t-case mounting, I don't know if it's the same pattern as the regular housing.
PostPosted: Fri Apr 04, 2003 3:09 am
It's the same, that is, the adapter that goes between the 727 and the tcase bolts in place of the 2wd housing. In other words, you can use a 2wd housing in place of the 4wd tcase adapter.
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Fri Apr 04, 2003 3:54 pm
Woo hoo! Thanks, Pilot.
 Post subject: ?
PostPosted: Fri Apr 04, 2003 5:56 pm
Didn't vans have short tailshafts?
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Fri Apr 04, 2003 6:38 pm
Don't think so, the one I have isn't.
