It is currently Mon Nov 16, 2026 12:02 pm
 Post subject: front u joint lube
PostPosted: Tue Oct 08, 2013 3:25 pm
Car Model: 75valiant custom
as the name implies, i have a 75 valiant. totally stock, 4 door california car. when i had the driveline out of the car, i found it was totally impossible to lube the front u-joint. yes, it had a zirc. it was just too tight of a fit to get ANY grease gun tip in there. i gave up and re-installed because i had to use the car.
so what gives? did they use special skinny tips back in the 70s? i can't believe mopar intended for me to disassemble the u joint to grease it while having a zirc in there.
help is appreciated.
PostPosted: Wed Oct 09, 2013 6:38 am
Here is the very tight space attachment I used in the seventies for greasing U Joints, they are still available:
I have had to remove drive shaft at times to get good grease application to front joint due to duel exhaust system cluttering up access to front joint.
PostPosted: Fri Oct 11, 2013 6:25 pm
VERY few factory automotive U-joints (60's-70's & up) came with zerk fittings- so it's likely a replacement- which means it was installed with the fitting poing the wrong way. I still use the same grease adapter as wjar when needed. There's an even slimmer version- it has a needle about 1/8" thick & a conical tip. You push the tip against the check ball & pump grease in. [url]http://www.zorotools.com/g/00059617/k-G4784053?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CKCm-saQkLoCFUOe4Aod-n8ATA[/url]
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Oct 11, 2013 8:10 pm
On a 7260 joint you will almost always need an extension like the one pictured above. I have one that is thinner than that. You can usually find them at Poop Boys or Otterzone.
PostPosted: Sat Oct 19, 2013 8:43 pm
Just recently, I saw a blurb about a device for forcing lube into a clogged zerk fitting. You use a hammer with it and it blasts the old junk out. I just can't find it just now.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Sat Oct 19, 2013 9:11 pm
You can usually replace zerk fittings
PostPosted: Sat Oct 19, 2013 9:42 pm
BC
http://www.northerntool.com/shop/tools/ ... _200430913
Users browsing this forum: Amazon [Bot] and 5 guests
