It is currently Mon Nov 16, 2026 9:49 am
 Post subject: Another clutch option?
PostPosted: Mon Oct 21, 2013 6:04 pm
Here is something I have never seen. Plus it is way out of my price range right now. I'd like to know if anyone has a report on how it works? The flywheel looks pretty cool.
http://www.hemiperformance.com.au/store ... ll%20Block
PostPosted: Mon Oct 21, 2013 7:37 pm
Nice find! It is pricey but I like the way it is designed. By cutting the ring gear teeth into the flywheel itself you could have a larger diameter mounting surface to take a real 10" cover without any notches. Anybody know what the exchange rate is on the Aussie Dollar? I wonder how early and late model crank hub diameters are accommodated.
PostPosted: Mon Oct 21, 2013 8:23 pm
6 Pack Dart
conversion US to AUS
http://www.xe.com/currencyconverter/con ... USD&To=AUD
Richard
 Post subject: Hmmm...
PostPosted: Mon Oct 21, 2013 9:03 pm
I wonder where they are made at...the disc looks like a 5 prong version of my spec Stage 3 clutch, and the cover looks exactly like the Spec clutch cover without the blue paint/powdercoating....
Flywheel looks good, although if the engine was high compression, it's be hard on the wallet if you wiped out a few teeth...
-D.idiot
