| Another clutch option? https://slantsix.org/forum/viewtopic.php?t=53654 |
| Author: | Rick Covalt [ Mon Oct 21, 2013 6:04 pm ] |
| Post subject: | Another clutch option? |
Here is something I have never seen. Plus it is way out of my price range right now. I'd like to know if anyone has a report on how it works? The flywheel looks pretty cool. http://www.hemiperformance.com.au/store ... ll%20Block |
| Author: | Exner Geek [ Mon Oct 21, 2013 7:37 pm ] |
Nice find! It is pricey but I like the way it is designed. By cutting the ring gear teeth into the flywheel itself you could have a larger diameter mounting surface to take a real 10" cover without any notches. Anybody know what the exchange rate is on the Aussie Dollar? I wonder how early and late model crank hub diameters are accommodated. |
| Author: | Fopar [ Mon Oct 21, 2013 8:23 pm ] |
conversion US to AUS http://www.xe.com/currencyconverter/con ... USD&To=AUD Richard |
| Author: | DusterIdiot [ Mon Oct 21, 2013 9:03 pm ] |
| Post subject: | Hmmm... |
I wonder where they are made at...the disc looks like a 5 prong version of my spec Stage 3 clutch, and the cover looks exactly like the Spec clutch cover without the blue paint/powdercoating.... Flywheel looks good, although if the engine was high compression, it's be hard on the wallet if you wiped out a few teeth... -D.idiot |
