It is currently Thu Feb 13, 2025 10:25 am
 Post subject: BBD step up pistin
PostPosted: Wed Oct 30, 2013 3:52 pm
Any clues on how to adjust the step up piston? I stupidly turned the hex screw out
83 B150 /6 4spd
97 JeepWrangler Sport 4.0
2001 VW Beetle TDI 5sp
2000 Nissan Xterra
73 Dodge B300 van
PostPosted: Wed Oct 30, 2013 3:54 pm
Give thanks to Uncle Dan!
PostPosted: Wed Oct 30, 2013 4:05 pm
Thanks once again Reed. The 83 van has been running pretty good the last couple of months, but I suddenly have some carb issues. It has a stumble and spudders at low speeds- Im thinking about going to a one barrel for I cant get better then 10 mpg
83 B150 /6 4spd
2000 Nissan Xterra
73 Dodge B300 van
PostPosted: Wed Oct 30, 2013 4:14 pm
Yep, vans get in the 10-13 MPG range. It takes some serious tuning and careful driving to get better than that. Make sure the carb is adjusted correctly, make sure you have no vacuum leaks, play with your timing curve, never go over 55 MPH, run as lightweight as possible, and install a vacuum gauge and drive to maximize vacuum.
Users browsing this forum: Semrush [Bot] and 26 guests
