It is currently Sat May 16, 2026 8:52 pm
PostPosted: Thu Nov 28, 2013 9:59 am
the rear brake hose (65 dart /6 auto 7 1/4) screws into the tee. looks like same length as a front hose, maybe different brand??? is this the same as front hose or should i just pay quite a bit more for what the parts store lists for the rear hose? which maybe is maybe made on the tee??? just wondering.....
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Sat Nov 30, 2013 8:09 pm
Good observation. While they are listing different part numbers on RockAuto, I see what you are saying about it looking like the fronts should interchange with the rear. They do appear to be the same length and have the same ends. Can you have your local parts store order one of each in, and then compare them before you purchase?
 Post subject: brake hose 65 dart
PostPosted: Sun Dec 01, 2013 3:56 pm
all the parts stores here priced the fronts for 9 in drums at like $22, classic ind had them for $10 and a 25% discount this weekend so i got 3 of the front hoses, my trans cooler lines i had to have, new front to rear fuel lin, and 5 LH 7/16 lug nuts not of the parts stores could seem to find!!!!! WOW!!
