Slant Six Forum https://slantsix.org/forum/ |
BBD step up pistin https://slantsix.org/forum/viewtopic.php?t=53725 |
Author: | vanmansl6 [ Wed Oct 30, 2013 3:52 pm ] |
Post subject: | BBD step up pistin |
Any clues on how to adjust the step up piston? I stupidly turned the hex screw out |
Author: | Reed [ Wed Oct 30, 2013 3:54 pm ] |
Post subject: | |
Quote: Here is the Carter BBD operation and repair manual (pdf)
Give thanks to Uncle Dan!
Author: | vanmansl6 [ Wed Oct 30, 2013 4:05 pm ] |
Post subject: | |
Thanks once again Reed. The 83 van has been running pretty good the last couple of months, but I suddenly have some carb issues. It has a stumble and spudders at low speeds- Im thinking about going to a one barrel for I cant get better then 10 mpg |
Author: | Reed [ Wed Oct 30, 2013 4:14 pm ] |
Post subject: | |
Yep, vans get in the 10-13 MPG range. It takes some serious tuning and careful driving to get better than that. Make sure the carb is adjusted correctly, make sure you have no vacuum leaks, play with your timing curve, never go over 55 MPH, run as lightweight as possible, and install a vacuum gauge and drive to maximize vacuum. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
