It is currently Fri Feb 21, 2025 2:06 pm
PostPosted: Thu Oct 24, 2013 1:44 pm
ANYBODY KNOW OF A BOLT ON WITHOUT GOING TO A EXAUST SHOP AEP says they don't make one! I would have to cut it because it's a low deck block. Thanks Dino
 Post subject: Nope...
PostPosted: Thu Oct 24, 2013 4:20 pm
The closest version is asking for a 1976 Feather Duster Header pipe then running the rest of it from stock pipe chunks from your local shop...slant six= custom exhaust for most non-stock applications...
PostPosted: Sun Oct 27, 2013 7:27 pm
Car Model: 1965 Barracuda 'S' auto
Dino, you got a welder? I made mine. bolt on 2 flanges and raise exhaust pipe to where you want it to ride, then tack up the new head pipe, remove at flanges and finish welding. I used a 2.25 x 90 cut and sectioned. Muffler shop cold make quick work of it probably pretty cheap.
I didn' t buy it, I built it.....
 Post subject: not cheap
PostPosted: Mon Oct 28, 2013 12:36 pm
This is a military town nothing is cheap. it's tight I needed a smooth radius. bit the bullet. $325.. all the way wit a 40 . I,ll be buried in this but it will be fun, I could build 3 small blocks for what I'll have in this one! LOL GREAT BUNCH OF HELP. THANKS TO ALL,THIS /6 THINGS GOTA HOLD ON ME. BEING A THREE ON THE TREE MAKES IT TIGHT!
 Post subject: Done thanks for the help
PostPosted: Thu Oct 31, 2013 1:55 pm
Found a gentleman retired NAVY has a setup in his garage. Beautiful work new flange and 2 1/2 to the back with a 40. has a momentary drone but after that big difference. waiting for the intake, bought the valves and springs. need info on a good street cam,450 +.
 Post subject: Next up...
PostPosted: Thu Oct 31, 2013 1:57 pm
Need to know what your compression ratio is...a "good street cam" varies from stock - 9:1 SCR for the cam Ted had...I can weigh in at a good street engine being 10:1 ratio with a 270 duration moderate lift cam...
We can't answer that until you give us more specifics...
 Post subject: Cam
PostPosted: Fri Nov 01, 2013 5:06 am
i,ll give mesurements when i tear it down. thanks Dino
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 68 guests
