| GM HEI 5 pin spark retard https://slantsix.org/forum/viewtopic.php?t=53782 |
| Author: | Slanty [ Wed Nov 06, 2013 1:46 pm ] |
| Post subject: | GM HEI 5 pin spark retard |
Everyone here prefers the GM 4 PIN HEI module swap.Net for a, little more you can get a module that can retard ignition timing 10 degrees.A 5 pin module for an 1980 Oldsmobile 260.It's like a 4 pin module except that it has a small 5th pin that retards timing when grounded.Good for hard hot starts or ping issues on hills. |
| Author: | Joshie225 [ Wed Nov 06, 2013 3:51 pm ] |
Hey, that could be the thing for guys running nitrous. Thanks for the info. |
| Author: | Ssg Pohlman [ Wed Nov 06, 2013 5:42 pm ] |
Or even turbo, once you go into boost have a Hobbs switch set up to ground it. |
| Author: | Slanty [ Wed Nov 06, 2013 7:31 pm ] |
Just use a pressue activated switch to ground it,or a toggle. |
| Author: | olafla [ Thu Nov 07, 2013 9:48 pm ] |
| Post subject: | Additional marine 8-pin modules with built-in advance curve |
The 5-pin module came in 3 versions, they differ in type of input signal to retard the ignition. All the 5-pin modules are used with distributors having conventional centrifugal and vacuum advance mechanisms. 1. HEI/EMR Electonic Module Retard, this is the one described here, it originally used various input signals to an electronic controller, that provided a ground signal to activate the retard mechanism. 2. HEI/ESC Electronic Spark Control, uses knock sensor and an electronic controller to provide a voltage signal to the module to activate the retard mechanism. 3. HEI/ESS Electronic Spark Selection, uses signals from pressure or vacuum, temperature and distributor into an electronic controller to provide a voltage signal to the module to activate the retard mechanism. 8-pin module with built in advance curve Not well known on the automotive scene, Delco also sold a marine HEI distributor kit to upgrade older boat engines to electronic ignition. The Delco Voyager Marine Distributor Ignition System was made for 4 cyl, V6 and V8 engines, and reportedly used the same module in all adaptations. These marine kits use a different 8-pin module, that provides a built-in advance timing curve, and works without using an ECM. The marine kit was delivered with a distributor without any mechanical or vacuum advance. The module could be an interesting alternative used with a Lean Burn distributor on a race engine. But there is of course no problem to use them with any distributor... An 8-pin module for a car will not work, they have an externally adjusted advance curve, HEI/EST - Electronic Spark Timing provided by an engine management unit. I have seen claims for 20-22° advance built into the marine Delco module, but in the curve I found, it starts on 11° and give 22° total advance. It may be incorrect, and it must be investigated further, because the engines the kit was intended for, all like around 30° total advance. I would guess that the curve shown is for a SBC V8. RPMS/Advance 700/11 750/12.5 800/13 1000/15 1250/16 1500/16.5 1750/17.5 2000/18.5 2250/19.5 2500/20.5 2750/21.5 2800/22 There is also the Mercruiser Thunderbolt Ignition system, that has the same functionality. There are several ignition mudules available. See this site for info: http://wolfiesenterprises.com/Ignition% ... 0Parts.htm Here are advance curves for the ignition modules used in Thunderbolt TBIV and TBV systems (for carburetted engines): http://www.mtboats.com/mercuryignitiona ... dules.html Olaf |
| Author: | wjajr [ Fri Nov 08, 2013 6:33 am ] |
Quote: These marine kits use a different 8-pin module, that provides a built-in advance timing curve, and works without using an ECM. The marine kit was delivered with a distributor without any mechanical or vacuum advance. The module could be an interesting alternative used with a Lean Burn distributor on a race engine
I have to agree in theory. The thing about marine engines is they operate more like a stationary engine with long duration steady throttle openings, and constant load, unlike a passenger car engine encountering gear changes, constantly changing load (hills, stop and go, and velocity), and constant throttle opening changes requiring an ever changing timing change during operation. A dedicated drag race engine has more in common with a marine engine where it operates mostly with one set of parameters, WOT for ¼ mile. |
| Author: | olafla [ Fri Nov 08, 2013 6:23 pm ] |
I also thought that those who wish to have some advance in the ignition timing on a race engine, would see it as a bonus to be able to reduce the possible sources for failure, by eliminating some moving parts. (and for at least one of you racers, some weight! ) Olaf |
