| Eickmann FED https://slantsix.org/forum/viewtopic.php?t=53786 |
Page 1 of 4 |
| Author: | ceej [ Wed Nov 06, 2013 8:31 pm ] |
| Post subject: | Eickmann FED |
Probably better start a thread on the FED. I'll put some photos up as time permits. http://i62.photobucket.com/albums/h93/H ... G_0230.jpg CJ |
| Author: | wvenable [ Thu Nov 07, 2013 3:03 am ] |
S.......ova.......b!!!!!! Thanks Ceej for sharing. Keep the pics coming! How long has the project been ongoing? |
| Author: | Will [ Thu Nov 07, 2013 4:05 am ] |
Nice!!!!! |
| Author: | Rick Covalt [ Thu Nov 07, 2013 4:11 am ] |
Super nice. Can't wait until some of these projects hit the tracks! Keep the pictures coming! Rick |
| Author: | ceej [ Thu Nov 07, 2013 6:56 am ] |
Quote: S.......ova.......b!!!!!! Thanks Ceej for sharing. Keep the pics coming! How long has the project been ongoing?
A couple of years. Longer if you count the trip Linda took to get the RED that wouldn't certify as a door stop for a poker game. Actual build has been going on this year in between customers with actual money. CJ |
| Author: | Kidd [ Thu Nov 07, 2013 7:31 am ] |
Looks awesome my friend. I bet it will be really fun!! |
| Author: | Danarchy [ Thu Nov 07, 2013 8:49 am ] |
![]() That thing is Insane! What is the pole coming out of the end of the crank? (is that where the second slant 6 is going? |
| Author: | Mike'68Dart [ Thu Nov 07, 2013 9:10 am ] |
That "pole", is for aligning the crankshaft center line with the differential. They don't use a driveshaft with U-joints, just a coupler shaft. |
| Author: | Dart270 [ Thu Nov 07, 2013 10:50 am ] |
Looks like fun, CJ! Shooting for the fastest /6 car ever...? Lou |
| Author: | ceej [ Thu Nov 07, 2013 11:02 am ] |
I doubt it will be the fastest. We'll see if it's the quickest though! CJ |
| Author: | slantzilla [ Sat May 14, 2016 6:29 am ] |
| Author: | Dart270 [ Sun May 15, 2016 7:51 pm ] |
Hope you get this car done, CJ. Notice has been given by Mr. Will Burns of Gloucester, VA ---> 9.09 @ 140 MPH, spinning through 1st gear. 8s should be served on the next outing, most likely. Lou |
| Author: | ceej [ Mon May 16, 2016 8:42 pm ] |
Good luck Will! I'm rooting for you!:D CJ |
| Author: | ceej [ Mon Jun 06, 2016 7:45 pm ] |
Got an update. The car is front and center in Gary's shop. Gary is having some machine work done on the blower mount at a cnc shop. His Bridgeport could do it, but it would be too time consuming. We are now on the third firewall. Mounting the starter in the customary location would result in having to disassemble the entire blower/intake/exhaust system to access the starter. We've got nozzle locations worked out for the fire suppression system now, and a banged up tractor pan will be heavily modified to fit over the girdle. A car pan is too tight. There is still the matter of the pump drive system, blower restraint system, and safety gear. The brand new 7 point harness Gary gave me needs to go in for recert. If my blower restraint plate will work, it will need to be re-webbed, though we haven't completely figured out where the head side anchoring will be done. The bottom of the Clifford plenum will sport two burst disks. The blower belt will be rubber, not Kevlar. Kevlar won't dampen harmonics. There will be no Harmonic Balancer on this engine. It will rely on the big rubber band up front for those duties. Still building. I'm hoping to get the car to the track this year! CJ |
| Author: | Dart270 [ Tue Jun 07, 2016 4:17 am ] |
Very cool! Glad to hear you are moving forward, CJ. Hope to see you in Woodburn in 2.5 weeks and we can catch up. Best, Lou |
| Page 1 of 4 | All times are UTC-07:00 |
