It is currently Sat Nov 28, 2026 11:48 am
PostPosted: Mon Nov 18, 2013 11:09 am
I needed to get a coil in case the one I have has issues. I have no car at the moment to go to a yard and look for parts. I have a pertronix 60130 on the way, and it has the male spark plug style connection for the dizzy. What can I do to plug this up to the distributor cap? I have some spare wires, but I don't know if this can be cobbled together. Anyone know where to get something that's going to work, from the internet? Anyone know what to look for? I've seen the Napa Belden 701050 mentioned, but 14" doesn't seem like enough reach to get to the the distributor cap to me. Can I just use a normal dizzy to spark plug wire?
1970 Plymouth Duster, 198 Slant Six, Super Six setup w/ EI conversion
http://www.semisynthetic.net/kill-9/gal ... p?album=34
PostPosted: Mon Nov 18, 2013 12:41 pm
Yes, you can use a standard spark plug wire. I did with a GM coil. Worst case is the plug boot needs a little trimming, but if it's not bonded to the wire you can just push the boot back.
PostPosted: Mon Nov 18, 2013 3:48 pm
Right on, thanks Joshua
