| Front wheel cylinders https://slantsix.org/forum/viewtopic.php?t=53896 |
| Author: | crickhollow [ Mon Nov 18, 2013 5:35 pm ] |
| Post subject: | Front wheel cylinders |
I have 2 Bendix 309560 front wheel cylinders NOS for my drum brakes.One is for the left wheel the other for the right wheel. They are different - the inlet tube connections are 180 degrees opposed. How can I tell which wheel cylinder is left and which is right? I have a 62 Signet. Thanks, Peter |
| Author: | Fopar [ Mon Nov 18, 2013 6:13 pm ] |
Look at the easiest way to put flex line on. Richard |
| Author: | 61 V200 [ Mon Nov 18, 2013 7:49 pm ] |
The threads where the flex line attaches to the cylinder should angle towards the rear of the car. The flex line should immediately be secured with a u-clamp as it exits the wheel cylinder. |
| Author: | Fopar [ Mon Nov 18, 2013 10:33 pm ] |
You see if he had tried to put them on wrong he would have a lot of fun putting the flex hoses on. Richard |
