It is currently Wed Nov 25, 2026 2:17 am
PostPosted: Tue Nov 19, 2013 7:13 pm
Hello Everyone,
I have my first Mopar project. I'm sure you guys probably forgot more than I will every know about these cars. I have a 67 barracuda /6 auto fastback. I'm in the process of getting it road worthy after sitting for 15yrs. I replaced all the brake components cylinders, springs, pads, master cylinder, and doctor diff master cylinder push rod. It's going well but I can't seem to find the 9" drum brake anchors/guides/retainers I have seen them called different things but they are the little wing looking washers that hold the pads on just behind the return springs. My car was missing them and they are very hard to find. I check auto zone, O'Reilly, advance auto, Napa, all the online stores like rock auto, classic industries, summit racing, and more. Can you guys please point me in the right direction your assistance is greatly appreciated.
Thanks, Denis
PostPosted: Fri Nov 22, 2013 4:47 pm
I missed this post. Have you found any Yet? I might have some,
PostPosted: Sat Nov 23, 2013 7:39 am
In a pinch I've just gotten a flat washer that would fit over the anchor pin & just ground the outside down until it was oval-shaped.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sun Nov 24, 2013 6:11 am
here is a 7 1/4 being parted out,
wll these brake parts work for you?
http://www.forabodiesonly.com/mopar/sho ... p?t=244202
 Post subject: Got guide Plates?
PostPosted: Sun Dec 29, 2013 3:42 pm
I want to take the time to thank you guys for the help Pierre found me some guide plates. They should work just fine. Now I just got put the front brakes back on. Bleed the lines and I should be in luck. Next improvement is wheels and tires. Thanks again guys
