| oil cap seal? https://slantsix.org/forum/viewtopic.php?t=53916 |
| Author: | Mike_64_Valiant [ Thu Nov 21, 2013 1:56 pm ] |
| Post subject: | oil cap seal? |
Is there a replacement seal for the valve cover oil cap? All of the 4 I have are brittle and falling apart. Maybe an aftermarket one is available? [/quote] |
| Author: | sagasky [ Thu Nov 21, 2013 5:57 pm ] |
Something like this? http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40 |
| Author: | Mike_64_Valiant [ Thu Nov 21, 2013 6:26 pm ] |
Nope those are all the breather cap. I need the oil fill cap seal. My valve cover has 3 holes one for cap one for pcv and one for breather. |
| Author: | Mike_64_Valiant [ Thu Nov 21, 2013 6:30 pm ] |
| Author: | Danarchy [ Thu Nov 21, 2013 7:24 pm ] |
http://www.ebay.com/itm/Mopar-Engine-Va ... 0802529564 or this http://www.jegs.com/i/Mopar+Performance ... 7Aod5G0AfQ ? |
| Author: | Greg Ondayko [ Fri Nov 22, 2013 7:24 am ] |
Quote: Nope those are all the breather cap. I need the oil fill cap seal. My valve cover has 3 holes one for cap one for pcv and one for breather.
Why don't you make one from some old inter tubes or sheet rubber.. Probably a nice set of tin snips, a pair of scissors and an xacto knife / Razor blade is all you need to make one. Greg |
| Author: | Joshie225 [ Fri Nov 22, 2013 8:09 am ] |
![]() STANT Part # 10066 $1.08 at Rockauto.com |
| Author: | Aggressive Ted [ Fri Nov 22, 2013 8:15 am ] |
| Post subject: | Oil cap rubber seal |
Why don't you make one from some old inter tubes or sheet rubber.. Agreed! pretty easy to make. I keep some sheet rubber handy for such needs. Besides making seals for the oil cap when they wear out, I also make them for radiator caps when they wear out and no longer recycle radiator fluid from the over flow tank. |
