It is currently Sun Oct 18, 2026 11:19 pm
 Post subject: DadTruck 83 D150
PostPosted: Sun Mar 30, 2014 2:16 pm
This 1983 D-150 is intended to be a good weather daily driver and occasional drag strip runner. It is the vehicle I have for 2014 M-D and Clay City,, so I plan to get it going the best that it is capable of.
Will never be a tire smoker,, what it will be, is yet to be determined.
here is a video taken today
http://www.youtube.com/watch?v=mPqicAkTrg0
I have started a spread sheet, listing the details from 2013 at Clay City. Plan to make a few t&t passes at local strips ahead of M-D, and I will add those on to the list.
here is the list with the 10 passes to date
https://www.flickr.com/photos/13718356@N02/13548018555/
I am expecting some measurable improvement from 2013 Clay City, now that I have fixed the proportioning valve and the front disks are releasing when the brake pedal lifts, and not 45 seconds later.
Today I re set the distributor timing,, went from 5 degrees initial to 10 degrees. The slant seemed to like that. I am also setting up a spare distributor to push the initial and mechanical advance beyond the 24 degrees it is now. I have a spare 2280 carb with larger jets that I want to try...
PostPosted: Sun Mar 30, 2014 5:15 pm
Poser
You damn hippie! Fix that bench seat and put the Ram on the hood. :lol: :lol: :lol:
PostPosted: Mon Mar 31, 2014 3:49 pm
WV,, there is a T&T at Muncie on April 16th,, to chart up a few more runs,
you want to go?
http://www.munciedragway.com/index.html
PostPosted: Tue Apr 01, 2014 10:05 pm
Looking forward to seeing ya (in truck) at M-D in May!
PostPosted: Tue Apr 01, 2014 11:20 pm
Another one hooked. :lol:
