| Tee fitting https://slantsix.org/forum/viewtopic.php?t=53972 |
| Author: | 1930 [ Fri Nov 29, 2013 12:09 pm ] |
| Post subject: | Tee fitting |
I cannot find the one that goes into the intake for my power brakes ect, anyone have a spare ? Every one I come across is broken |
| Author: | Supercharged SL6 [ Fri Nov 29, 2013 7:01 pm ] |
If it don't have to look OE, hardware or auto parts store should have a street tee or a tee with a nipple, then add fittings to the two open holes for what you need |
| Author: | 1930 [ Sat Nov 30, 2013 3:26 am ] |
Quote: If it don't have to look OE, hardware or auto parts store should have a street tee or a tee with a nipple, then add fittings to the two open holes for what you need
I would like a factory look if possible. Ill find one eventually, just thought someone here might have one laying around. Thanks though
| Author: | GTS225 [ Sat Nov 30, 2013 5:07 am ] |
Where you located, and how many outlets do you need off that manifold nipple? (single or multi-hose) I might have something out in the cave, but I'll have to take a peek later today and get back to you. Roger |
| Author: | 1930 [ Sat Nov 30, 2013 12:22 pm ] |
Quote: Where you located, and how many outlets do you need off that manifold nipple? (single or multi-hose)
Thanks, the tee would have to have a large for brake booster and a small for the vacuum hoses on the A/C. I might have something out in the cave, but I'll have to take a peek later today and get back to you. Roger I am in Brandon Florida, my e-mail is jhason2@yahoo.com if you prefer that. |
| Author: | 1930 [ Tue Dec 10, 2013 3:27 pm ] |
For anyone interested as it turns out Ford F-150, expeditions and such have a multiple nipple fitting that is a direct bolt in for the slant six. If anyone would like a picture let me know. Looks factory. There is a low version that I was not able to find ( but I didnt look very hard ) Mine sticks up and out of the intake a couple of inches but in my opinion it looks much better than the brass fittings I was considering from Napa. |
