| Disc brake making clicking noise (rotor warped?) https://slantsix.org/forum/viewtopic.php?t=54016 |
| Author: | Pierre [ Fri Dec 06, 2013 5:37 pm ] |
The pad should not have that much play in the caliper. Take the pad out of the caliper and use a hammer to bend the tab downward - check both sides. It should be tight enough just to get it in the caliper. Once it's back in and assembled make sure the bottom of the pad doesn't hit the rotor hat - otherwise you'll get a scraping type noise too. If it still does hit - like mine did - I ground that lip of the pad down with a dremel. Make sure the spindle nut is properly tightend, that'll affect runout. |
| Author: | robertob [ Sat Dec 07, 2013 12:16 pm ] |
Also there is a rubber band that comes in the rebuild kits that sits between the retainer and the pad, that helps with the clicking noise. Of the three cars that I converted they all clicked in certain situations. Usually when you just touch the brakes at low speed. |
| Author: | Fab64 [ Sun Dec 08, 2013 9:59 am ] |
Thanks, guys. I will check the spindle nut, then try bending the tabs on the pad. I appreciate the help. Roger |
| Author: | olafla [ Sun Dec 08, 2013 5:59 pm ] |
I am even firmer than Pierre on his matter; I usually bend the tabs so much that I have to use a clamp to press them in place. It is probably not correct, but you cannot break anything, and that clicking noise can make you go nuts! Olaf |
| Author: | Fab64 [ Mon Dec 09, 2013 5:22 pm ] |
Ok, I finally got a chance to do this today, and it was nowhere near as difficult as I'd imagined it would be. In fact, I really learned a lot. I discovered I didn't have to remove the caliper bracket at all, just the one bolt which holds the rectangular piece in place at each end of the caliper. I also thought the piston would tend to pop out if I didn't wedge something in there, but it stayed in without a problem. I bent the tabs down on the brake pad (I only did the right side, since I haven't heard any noise from the left), and it pretty much eliminated the noise. It may not be quite as tight as it should be, but it's fairly snug in there. Thanks for the help, guys!! Now on to the next problem! Roger |
