| OK, Gang.......... https://slantsix.org/forum/viewtopic.php?t=54033 |
| Author: | GTS225 [ Mon Dec 09, 2013 7:58 pm ] |
| Post subject: | OK, Gang.......... |
Need to locate a pair of spool mounts for a slant. Have the engine brackets, but they're bare. Locally, I can't get the mounts with the outer steel sleeve, just the rubber insert. Rock Auto wants to charge me $5 for the "privilage" of placing a phone-in order. I DON'T send my financial account numbers over an internet connection for any reason. Any suggestions where I might be able to round up a pair of spools? Roger |
| Author: | Rob Simmons [ Tue Dec 10, 2013 7:35 am ] |
Hey Roger, You'll be able to find them here pretty easily. Just post a Parts Wanted ad. |
| Author: | Charrlie_S [ Tue Dec 31, 2013 5:29 am ] |
Roger, did you find the mounts, yet? I have a pair of inserts, if that is what you need. PS: If this had been in the parts wanted, I would have responded sooner. |
| Author: | GTS225 [ Tue Dec 31, 2013 7:20 pm ] |
Oops, sorry. I also found out that there is a difference in outer dimensions between car and truck/van mounts. BTW, Charlie......what exactly do you mean by "inserts"? I take that word to mean just the rubber with a steel inner sleeve, and one would have to have the outer sleeve still in the engine bracket. The reason I interpret it that way is due to finding poly "inserts" available on the net, (at $37 each), and they were exactly that. Just a poly "rubber" insert with a steel inner sleeve. Roger |
| Author: | Charrlie_S [ Tue Dec 31, 2013 8:10 pm ] |
Quote: Oops, sorry.
The stock style "inserts" I have, are rubber, with a steel inner sleeve, and a steel outer shell. They are identical to the ones on Rockauto, at less then $2.00 each.
| Author: | Reed [ Tue Dec 31, 2013 9:46 pm ] |
Quote: I also found out that there is a difference in outer dimensions between car and truck/van mounts.
Trucks and vans never got spool mounts, They were sandwich mount until the end of the line in 87.
| Author: | DusterIdiot [ Tue Dec 31, 2013 11:04 pm ] |
| Post subject: | And... |
Quote: They were sandwich mount until the end of the line in 87.
And the LA engines still had them through the mid-90's...but they had catch hooks to keep the mount together if the rubber failed (too bad they didn't do that from the 60's to 1972 in the cars).-D.Idiot |
| Author: | GTS225 [ Wed Jan 01, 2014 4:34 am ] |
Quote: The stock style "inserts" I have, are rubber, with a steel inner sleeve, and a steel outer shell. They are identical to the ones on Rockauto, at less then $2.00 each.
******************************************************OK...that's what I got from the local CarQuest. So I'm using an incorrect term, (at least mentally), for the insert verb. I already had the engine brackets, just not with inserts in them. Thanks for the offer, though. Roger |
| Author: | GTS225 [ Wed Jan 01, 2014 4:40 am ] |
Quote: Trucks and vans never got spool mounts, They were sandwich mount until the end of the line in 87.
****************************************************Hmmmmm. Interesting.....so what do I have, then? I have two sets of engine brackets for a slant, that use spool inserts. One set utilizes inserts for a '75 Dart. My other set has larger oval cutouts for the insert, and the A-body inserts are too small to even consider using in them. Oohhh....might I have a set from an F-body? Roger |
