need a pro's advice full rebuild kit or not
https://slantsix.org/forum/viewtopic.php?t=54084
Author:  oldreadinggus [ Tue Dec 17, 2013 8:30 am ]
Post subject:  need a pro's advice full rebuild kit or not
:? my 75 dodge van with a 225 slant 6 -3 speed 250 or 230 tranny...,going in for complete tear down.....bodywork,paint,the works, need advice from the pro's on engine ..full rebuild or not...motor is going to tore down and redone...should i go the with the full rebuild kit,...pistons ,cam shaft,timing chain, rings, ect....or should i only need to change certain parts...motor sound good but ...theres is some tapping,but no knocks,...if so where can i find mopar rebuild kits that are specific to this dodge motor .....im am not a mechanic and only have a basic understanding of the process... so while being in paint shop my mechinic is going to do all this work.rebuild motor and tranny 1600.00 + parts....so i really really need some real pro (printable )..advice and a recipe on how to proceed without costing me fortune.....thanks john in pa
Author:  Ssg Pohlman [ Tue Dec 17, 2013 8:44 am ]
You are going to want to tell us if youre going for mild or wild. Your driving type and other details. Most likely you'll want low end torque so do a search for a bit and read up. I know aggressive ted has a torquer build and dadtruck done a lot of research on his which is told to be a stump puller.
Author:  oldreadinggus [ Tue Dec 17, 2013 9:12 am ]
mild...basic driver ,city ...not speed way...,base model van as base as u can get in 1975, cheapest way to go with best long lasting results (long lasting effects ) looking for longevity ...thanks i think
Author:  Joshie225 [ Tue Dec 17, 2013 9:25 am ]
Backing way, way up...
What are your transportation needs? Why do you want to meet that need with a 40 year old van?
