rod style carb return spring??
https://slantsix.org/forum/viewtopic.php?t=54158
Author:  barbee6043 [ Fri Dec 27, 2013 6:38 am ]
Post subject:  rod style carb return spring??
/6 rod style 1920, i can't see anyplace for return spring to go on carb linkage ? surely has to be top end near the 2 screws.? but no little hole or slot for it. couldn't find any help under search.
Author:  robertob [ Fri Dec 27, 2013 8:34 am ]
It goes in the middle of the rod, down to a tab that is under one of the starter bolts.
Author:  barbee6043 [ Fri Dec 27, 2013 9:59 am ]
Post subject:  spring
the spring i'm referring to is the spring at the carb throttle. ??
Author:  barbee6043 [ Fri Dec 27, 2013 4:41 pm ]
O K carb has no spring , just the one at the rod. i adjusted the rod at gas pedal and all works great now!!!
