| The oil pump drive gear question https://slantsix.org/forum/viewtopic.php?t=54169 |
| Author: | ceej [ Fri Dec 27, 2013 9:32 pm ] |
| Post subject: | The oil pump drive gear question |
OK, so I've been talking to various racers about the diameter of the OP drive gear shaft. We're trying to find a happy spot for an interference gear. I measured the Melling pump I picked up from a group buy a few years ago. It measured .4850" with my dial calipers. I decided that I needed to be a bit more accurate to make sure. I broke out my micrometers, calibrated them to the appropiate standard, and got .4850" which makes me feel really good about my dial calipers! The .500 gear from a distributor will not work. What is the small diameter gear for the SBC? how many teeth, and what diameter is the gear hobbed on? There is a smaller diameter shaft size for that gear. I'm wondering if we can use that bronze gear for oil pumps on billet cams... CJ |
| Author: | slantzilla [ Sat Dec 28, 2013 2:31 am ] |
Somewhere in my treasures I have a bronze gear for a Slant oil pump. I think the Cox Bros. had them made. |
| Author: | sandy in BC [ Sat Dec 28, 2013 6:43 am ] |
When it gets light I will see if I have a SBC oil pump near the top of the pile. If not this morning ....I will check after my ski lesson with my 3 yearold grand daughter,,,, |
| Author: | sandy in BC [ Sat Dec 28, 2013 8:18 am ] |
LMAO/////of course its the dist drive gear on a SBC,,,, The small shaft size is .491. |
| Author: | sandy in BC [ Sat Dec 28, 2013 8:26 am ] |
The outside dia of the gear is ~1 3/16.....it has 13 teeth Measured and counted on a 7 pin EFI dist (as far as I know they are all the same) |
| Author: | sandy in BC [ Sat Dec 28, 2013 8:30 am ] |
Crower makes a .427 shaft size gear http://www.summitracing.com/int/parts/c ... /chevrolet |
| Author: | DadTruck [ Sat Dec 28, 2013 2:47 pm ] |
I have no idea if this gear is even close but mopar part number p3690874 has a bronze gear http://www.jegs.com/i/Mopar+Performance ... 4/10002/-1 |
