| 1945 carb https://slantsix.org/forum/viewtopic.php?t=54229 |
Page 1 of 3 |
| Author: | ceej [ Sun Jan 05, 2014 3:04 am ] |
If you look down through the links in the FAQ you will see "Carburetor operation and repair information." When you arrive at that page, there will be a link for "Holley 1945..." right at the top. CJ |
| Author: | 1930 [ Sun Jan 05, 2014 3:16 am ] |
Quote: If you look down through the links in the FAQ you will see "Carburetor operation and repair information."
Thanks, still cannot find it, I moved the question over to the site issues place.
| Author: | Reed [ Sun Jan 05, 2014 7:02 am ] |
![]() This is the idle air enrichment valve that was used on some, but not all, carburetors. It is a vacuum operated device, but I am not 100% sure off the top of my head how one goes about hooking it up properly. You need to find the manual you have been referred to and read up on it. If you are positive that the carb is off of a 75 slant six, then you may need to actually track down a 1975 factory service manual and see how that fitting is plumbed into the vacuum system on the engine. ![]() That fitting is not supposed to come out of the carb. Over time the fitting has been worked loose or the sealant used to hold the fitting in the carb body has worn out or been eaten away by gasoline fumes. You could try resealing the fitting in the carb body and sealing it with something like locktite or RTV sealant. Fine, HERE is the Holley 1945 manual, and HERE is the Chrysler training video on the Holley 1945 carb. I highly recommend reinstalling the charcoal canister. There is really no good reason not to have one. It has no negative effect on performance, it saves you money by capturing and storing gasoline fumes that would others evaporate out of the carb and pollute the atmosphere, and it helps your engine start easier. |
| Author: | 1930 [ Sun Jan 05, 2014 8:49 am ] |
Quote: ![]() This is the idle air enrichment valve that was used on some, but not all, carburetors. It is a vacuum operated device, but I am not 100% sure off the top of my head how one goes about hooking it up properly. You need to find the manual you have been referred to and read up on it. If you are positive that the carb is off of a 75 slant six, then you may need to actually track down a 1975 factory service manual and see how that fitting is plumbed into the vacuum system on the engine. ![]() That fitting is not supposed to come out of the carb. Over time the fitting has been worked loose or the sealant used to hold the fitting in the carb body has worn out or been eaten away by gasoline fumes. You could try resealing the fitting in the carb body and sealing it with something like locktite or RTV sealant. Fine, HERE is the Holley 1945 manual, and HERE is the Chrysler training video on the Holley 1945 carb. I highly recommend reinstalling the charcoal canister. There is really no good reason not to have one. It has no negative effect on performance, it saves you money by capturing and storing gasoline fumes that would others evaporate out of the carb and pollute the atmosphere, and it helps your engine start easier. I am letting it cool down now to see if I can mimic the same scenario. I see now what all the talk was about when it came to throttle shafts being worn, just wiggling the old original carbs shaft and their is alot of slop, up down, side to side ect. At least this new carb I picked up has no movement whatsoever. Even if it still needs gone thru I have a better starting point I guess because of that. I am printing out the 1945 manual as I type and will read and re-read to try and get a better understanding. |
| Author: | wjajr [ Sun Jan 05, 2014 9:12 am ] |
Quote: Ok great, just for the heck of it switched carbs, this new one started the truck, idled fine/fantastic but it would seem at this point when the engine was up too operating temp. the carb decided to no longer idle.
While choke is on it can mask a vacuum leak. On engine up to operating temperature close choke and see if idle smooths out, if so start looking for vacuum leak. Check trueness of carburetor base with a good straight edge, a deformed base will present a big vacuum leak that spraying car cleaner may not detect because size or length of leaking contact area. Other suspects would be vacuum advance, throttle return dashpot if equipped or any new vacuum operated devices introduced when second carburetor was installed. |
| Author: | 1930 [ Sun Jan 05, 2014 10:26 am ] |
Quote: Quote: Ok great, just for the heck of it switched carbs, this new one started the truck, idled fine/fantastic but it would seem at this point when the engine was up too operating temp. the carb decided to no longer idle.
While choke is on it can mask a vacuum leak. On engine up to operating temperature close choke and see if idle smooths out, if so start looking for vacuum leak. Check trueness of carburetor base with a good straight edge, a deformed base will present a big vacuum leak that spraying car cleaner may not detect because size or length of leaking contact area. Other suspects would be vacuum advance, throttle return dashpot if equipped or any new vacuum operated devices introduced when second carburetor was installed. This carb is different still than the carb that is shown in the 1945 manual I downloaded, the low idle speed adjustor screw for instance is not on the carb that I am working on and quite frankly I do not see how to adjust the idle speed. On the rear of the solenoid/plunger deal that is on my original carb the adjustment is made there for idle ( again different from the 1945 manual I downloaded ) and I was able to easily adjust the idle but I simply am not seeing where the adjustment is made on this 1975 carb. I will check out the things you mentioned and report back though. It is popping thru the carb ( sometimes ) after warmed up and I try to give it gas, if I am ever so gentle than I guess I can get it too get some Rpms up but it still seems to be struggling. I have re-checked the timing and it is set at about 10-12 maybe 13 or 14 BTDC. No dieseling like it had been. |
| Author: | 1930 [ Sun Jan 05, 2014 10:54 am ] |
While choke is on it can mask a vacuum leak. On engine up to operating temperature close choke and see if idle smooths out, if so start looking for vacuum leak. Check trueness of carburetor base with a good straight edge, a deformed base will present a big vacuum leak that spraying car cleaner may not detect because size or length of leaking contact area. Other suspects would be vacuum advance, throttle return dashpot if equipped or any new vacuum operated devices introduced when second carburetor was installed. I guess I will need to find the specific info for this 1975 carb including adjustment procedures and preferably tear down/re-assy procedures. If anyone here can help with this info let me know. Doing a google search and not coming up with anything specific. Trying to find a manual is only showing me Haynes, if they are anything like Chiltons than they are useless from what I have. EDIT: Still searching for clues/answers, I am seeing posts that are giving details such as ..........I also noticed that the accelerator pump link is in the middle slot on my Carb which I understand is for manual transmissions? It needs to go in the top slot for the Auto? .............. I know nothing about such things nor would dream of looking for such problems. I may have too throw in the towel on this carb. Tough to fix something when you dont know what your doing. If there is anyone here that has alot of carb experience with this particular carb and has the time to help me work thru this thru e-mail than I would like to go thru it thoroughly and correctly. I understand though that time is hard to come by for everyone. In the meantime Im gonna keep piddling along with it Thanks for the efforts |
| Author: | ceej [ Sun Jan 05, 2014 11:51 am ] |
There is a Frequently Asked Questions "Thread" in the Engine area of the Forum. Look there. It is a sticky near the top. CJ |
| Author: | 1930 [ Sun Jan 05, 2014 2:07 pm ] |
[quote="Reed"] ![]() This is the idle air enrichment valve that was used on some, but not all, carburetors. It is a vacuum operated device, but I am not 100% sure off the top of my head how one goes about hooking it up properly. You need to find the manual you have been referred to and read up on it. If you are positive that the carb is off of a 75 slant six, then you may need to actually track down a 1975 factory service manual and see how that fitting is plumbed into the vacuum system on the engine. Reed, dont you think that I should be able to use the air horn from one of these spare carbs to eliminate this deal? Also dusteridiot mentioned something about checking the air horn too make sure it was not warped, ( If I understood correctly ) didnt go into any detail. What can be recommend for this? |
| Author: | 1930 [ Sun Jan 05, 2014 2:08 pm ] |
Quote: There is a Frequently Asked Questions "Thread" in the Engine area of the Forum. Look there. It is a sticky near the top.
Im gonna check it out now, thanks
CJ |
| Author: | Aggressive Ted [ Sun Jan 05, 2014 2:12 pm ] |
Did you pop the top on the new one to see if the float bowl is full of old varnish or any other debris? Did you down load the 1945 manual from the Engine FAQ section? Carbs manuals are about 15 or so titles down the list. Look for this..... Post subject: Carburetor operation & repair information (Fri Jan 02, 2009 5:03 pm) Reply with quote Here is the Holley 1945 operation and repair manual (pdf), and here is the Chrysler training film on the Holley 1945. The training film should really help you with your questions. Yes, I do run the fuel vapor canister as it eliminates the fuel smells from under the hood and makes for a tidy set up. Even though I replaced my 1945 with a 1920 Economaster it has the similar fittings and lines. These Holley carbs are not hard to tune.....just follow the instructions. |
| Author: | DusterIdiot [ Sun Jan 05, 2014 2:20 pm ] |
| Post subject: | 2 things... |
Quote: Also dusteridiot mentioned something about checking the air horn too make sure it was not warped, ( If I understood correctly ) didnt go into any detail. What can you recommend for this?
Basically when you pull it apart for cleaning, use a straight edge on the mating surfaces and see if they are indeed "flat" (you can use a thin feeler gauge to check between the straight edge and mating surface...say a .003 if you have one in your set).The Idle Air Enrichment Valve can be left alone if you live anyplace below Denver, just leave it uncapped and it will not function for the flat landers and hill drivers... The linkage adjustments and choke plate clearance can also be found in your rebuild kit instruction sheet (and you can change the adjustments to suit your vehicle as needed). My first carb to rebuild was a Carter BBD of a 1969 383, with no experiece I just took it apart and laid all the pieces in order that I disassembled it then cleaned each part and followed the instructions in the rebuild kit to reassemble and adjust...It's not that hard, just takes time. Note that swapping parts sometimes works, or can be a disaster...this is why reman carbs have such a bad rep, they just throw a set of parts from 3 different carbs together and expect the thing to run. -D.Idiot |
| Author: | 1930 [ Sun Jan 05, 2014 5:05 pm ] |
Quote: Did you pop the top on the new one to see if the float bowl is full of old varnish or any other debris?
No I had not done that yes cause I do not have the gasket set yet, I figured no sense pulling it apart if I could not put it back together cause no new gasket set. Did you down load the 1945 manual from the Engine FAQ section? Carbs manuals are about 15 or so titles down the list. Look for this..... Post subject: Carburetor operation & repair information (Fri Jan 02, 2009 5:03 pm) Reply with quote Here is the Holley 1945 operation and repair manual (pdf), and here is the Chrysler training film on the Holley 1945. The training film should really help you with your questions. Yes, I do run the fuel vapor canister as it eliminates the fuel smells from under the hood and makes for a tidy set up. Even though I replaced my 1945 with a 1920 Economaster it has the similar fittings and lines. These Holley carbs are not hard to tune.....just follow the instructions. Yes I down loaded and printed, no I did not see the film yet, my computer does not have the software to read it, I will try opening it on another comp. Will check everything out, thanks |
| Page 1 of 3 | All times are UTC-08:00 |
