| Carb to manifold gasket https://slantsix.org/forum/viewtopic.php?t=54234 |
| Author: | 1930 [ Sun Jan 05, 2014 4:46 am ] |
| Post subject: | Carb to manifold gasket |
I know these have some sort of insert to prevent from crushing but are these at all re-usable. A few days ago I was switching out carbs trying to find out what of what I had might work best. I bolted and un-bolted prob. a half dozen carbs. I guess at this point I am going to check for leaks with some starting fluid sprayed at the base of the carb but I am curious to know if these gaskets can generally be re-used. My local parts stores do not stock them. Cheap enough but the wait stinks. |
| Author: | wjajr [ Sun Jan 05, 2014 5:39 am ] |
I have been using Mr. Gasket Ultra-Seal III Carburetor Base Gaskets for several years. It is reusable, and has survived many, meny carb tuning sessions requiring carb R & R. I think I have used about four of them since 2008. |
| Author: | DusterIdiot [ Sun Jan 05, 2014 8:06 am ] |
| Post subject: | Rats! |
Quote: I have been using Mr. Gasket Ultra-Seal III Carburetor Base Gaskets for several years. It is reusable, and has survived many, meny carb tuning sessions requiring carb R & R. I think I have used about four of them since 2008.
He's using a Holley 1945 1 barrel, He'd have to make a custom gasket patterned off his current used one...but he's going to want the stocker gasket as it's 1/2" thick to help prevent fuel bowl boil over on shut down (and he might want to look into Ted's heat sheild as well once he' gets it tuned and running).-D.idiot |
