| need information for efi slant 6 supplier america 2014 https://slantsix.org/forum/viewtopic.php?t=54314 |
| Author: | dirty hands [ Mon Jan 13, 2014 9:59 pm ] |
| Post subject: | need information for efi slant 6 supplier america 2014 |
read through the forum on this subject of efi some were posted years ago just need to know what EFI for slant6 setups are is currently available a supplier for all parts to contact spose will get prices form him thanks |
| Author: | Doctor Injector [ Fri Jan 17, 2014 8:24 am ] |
| Post subject: | Slant six EFi |
There is a tone of stuff, you just have to look. You can follow the really great tech article from Bob DiBase http://www.slantsix.org/articles/dibias ... ersion.htm You could use a TBI kit from FAST http://www.fuelairspark.com/fas/ You can purchased matched fuel injectors. http://www.doctorinjector.net/7343.html What are you looking for? |
| Author: | DusterIdiot [ Fri Jan 17, 2014 2:00 pm ] |
| Post subject: | Diy |
there are no "plug and play kits", you basically just get the parts from a manufacturer and do it yourself. -D.Idiot |
| Author: | Matt Cramer [ Wed Jan 22, 2014 11:26 am ] |
| Post subject: | Re: Diy |
Quote: there are no "plug and play kits", you basically just get the parts from a manufacturer and do it yourself.
Some of the TBI setups may be drop on, but I'm not sure how well they do on fuel distribution.-D.Idiot Clifford did make a couple ready to go EFI manifolds, but there wasn't much demand for them and they stopped building them. (And they aren't the easiest outfit to order from, either). A while ago, I tried to mentally piece out what a bolt on kit might look like with off the shelf parts from a number of sources: http://www.slantsix.org/forum/viewtopic ... highlight= Such a setup would use Extrudabody throttle bodies on a Pierce manifold intended for Weber DCOEs. A couple of the parts I had listed are no longer available or have gone up in price a little. Or you could have a machine shop rework a four barrel intake manifold - that's what I did.
