| Best Starter for the Slant Six ? https://slantsix.org/forum/viewtopic.php?t=54380 |
| Author: | 1957guy [ Mon Jan 20, 2014 7:29 pm ] |
| Post subject: | Best Starter for the Slant Six ? |
I've seen a couple of older Valiants and Lancers ( 1961 and 1962 models ) sporting a later model and much smaller starter motor. I was thinking of replacing my original unit with one of these if someone can tell me what I should ask for at the local parts store. |
| Author: | ILMopars [ Mon Jan 20, 2014 7:52 pm ] |
Lol, a smartass response would "the one that fits" |
| Author: | 1957guy [ Mon Jan 20, 2014 7:59 pm ] |
When I asked one of the small gear reduction starter owners about his unit he said that it was a popular Chrysler V6 OEM type replacement, Have any ideas on how to narrow it down a bit ? |
| Author: | dirty hands [ Mon Jan 20, 2014 8:01 pm ] |
looking for an american supplier online but no luck |
| Author: | ceej [ Mon Jan 20, 2014 8:02 pm ] |
'89-'01 RWD Mopar 3.9, 5.2, or 5.9 engine. CJ Edit: $30-$50 at a auto wrecker near you! Might need to change the connections, but it's easy to do. The one in my Plymouth has been in there seven years. The '94 Dakota 5.2 starter had a factory heat shield. Get that too. |
| Author: | 1957guy [ Mon Jan 20, 2014 8:57 pm ] |
Thanks for the starter info……Changing subject….Anyone know where to find the rubber bushing that the throttle linkage snaps into on the early Carter one barrels ? |
| Author: | DusterIdiot [ Tue Jan 21, 2014 5:37 am ] |
| Post subject: | Is your's direct drive...? |
Quote: I've seen a couple of older Valiants and Lancers ( 1961 and 1962 models ) sporting a later model and much smaller starter motor. I was thinking of replacing my original unit with one of these if someone can tell me what I should ask for at the local parts store.
Just to make sure, does your Lancer or Valiant use the gear reduction starter or is it the early direct drive starter? (Some of the 60-61's got the Direct Drive starter...and you can't replace them with the late starter as the tooth count and pitch on the starting gear is different).-D.Idiot |
| Author: | Wesola78 [ Tue Jan 21, 2014 7:53 am ] |
My '78 Volare 225 has a starter for a '93 Dakota with a V6. I got it from O'Reilly Auto Parts, which is my part-time job. |
| Author: | 64ragtop [ Tue Jan 21, 2014 9:42 pm ] |
Quote: Thanks for the starter info……Changing subject….Anyone know where to find the rubber bushing that the throttle linkage snaps into on the early Carter one barrels ?
I found that bushing on ebay. Kinda pricey, though. A piece of rubber hose that's snug in the bracket on the throttle shaft will work. A small hose clamp will keep it from wandering. BC |
| Author: | emsvitil [ Wed Jan 22, 2014 2:32 am ] |
Quote: Quote: Thanks for the starter info……Changing subject….Anyone know where to find the rubber bushing that the throttle linkage snaps into on the early Carter one barrels ?
I found that bushing on ebay. Kinda pricey, though. A piece of rubber hose that's snug in the bracket on the throttle shaft will work. A small hose clamp will keep it from wandering. BC that's what I did........ |
