It is currently Tue Nov 17, 2026 4:39 pm
PostPosted: Mon Jan 27, 2014 7:52 am
trying to replace drivers side rear axle bearing and have never done so. wondering what is involved..thanks
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Jan 27, 2014 9:15 am
The hardest part of the job is getting the old bearing removed from the axle.
Some tips:
You can use a big chisle & hammer to "V" the bearing "lock ring" and that will release it from the shaft.
Use a "wizzer wheel" to "slit & split" the bearing races if you do not have a press and bearing "spreader". (as shown)
A section of pipe and heating the bearing & lock ring, will make new bearing installation easier.
