coil for HEI
https://slantsix.org/forum/viewtopic.php?t=54397
Author:  65 dartman [ Thu Jan 23, 2014 10:46 am ]
Post subject:  coil for HEI
On my 87 D100 I've gutted the stock ECM and will be mounting the HEI module inside. Is there a stock looking canister style coil available to use with the HEI. I know I can use the GM coil/bracket/HEI assembly as SSDan mentioned in the HEI thread but I'd like to keep the engine compartment stock looking.
Author:  Rick Covalt [ Thu Jan 23, 2014 11:10 am ]
2 of our 3 trucks are running the original factory coil.
Rick
Author:  65 dartman [ Thu Jan 23, 2014 1:23 pm ]
I was under the impression the coil needed to be a high output coil.
Author:  Reed [ Thu Jan 23, 2014 1:34 pm ]
Doesn't have to be. You get more benefit if it is, though.
Author:  SlantSteve [ Thu Jan 23, 2014 2:25 pm ]
I used a pertronix oil filled coil, .6 ohm I think, looks exactly like a stock coil. Cheers
Author:  slantvaliant [ Sat Feb 01, 2014 7:50 pm ]
I used an Accel 8140 with HEI for years. It was yellow, but a little paint would fix that.
