| LCA Interchangeability https://slantsix.org/forum/viewtopic.php?t=54406 |
| Author: | Acuda4me@AOL.com [ Thu Jan 23, 2014 9:15 pm ] |
| Post subject: | LCA Interchangeability |
I have a 74 dart with 225 and 9" drum brakes. I'm looking to pickup some junkyard LCA's so I can have the bushings pressed in/out in advance. Is the LCA different between Disc and drums or am I safe getting LCA's off a disc brake car? |
| Author: | Pierre [ Thu Jan 23, 2014 9:44 pm ] |
Your safe as far as drums/discs. The only possible difference is the stock sway bar mounts changed when going to bbp. If your not using a stock sway bar your fine. |
| Author: | Acuda4me@AOL.com [ Fri Jan 24, 2014 10:09 am ] |
So, to be clear, the lower ball joint connection point is identical? |
| Author: | Matt Cramer [ Fri Jan 24, 2014 10:57 am ] |
Quote: So, to be clear, the lower ball joint connection point is identical?
Yes, it is.
