| is there a image/s on how to replace 7.25 axle bearings ? https://slantsix.org/forum/viewtopic.php?t=54437 |
| Author: | USAJon [ Mon Jan 27, 2014 7:52 am ] |
| Post subject: | is there a image/s on how to replace 7.25 axle bearings ? |
trying to replace drivers side rear axle bearing and have never done so. wondering what is involved..thanks |
| Author: | Doc [ Mon Jan 27, 2014 9:15 am ] |
The hardest part of the job is getting the old bearing removed from the axle. Some tips: You can use a big chisle & hammer to "V" the bearing "lock ring" and that will release it from the shaft. Use a "wizzer wheel" to "slit & split" the bearing races if you do not have a press and bearing "spreader". (as shown) A section of pipe and heating the bearing & lock ring, will make new bearing installation easier. DD
