It is currently Mon Oct 26, 2026 10:35 am
PostPosted: Thu Apr 10, 2003 5:18 pm
Hey Guys, is there a way to calibrate my oil pressure gauge
on my 1967 A100?
I've tried 2 different stock gauges including a new one. The used
one reads 20psi and the new one reads 30psi. I hooked up an
autometer mechanical gauge just to check the pressure and it reads
44psi at idle and 47psi at cruise.
Is there a way to calibrate the stock gauges??
Thanks in advance
Mike in WA
 Post subject: ?
PostPosted: Thu Apr 10, 2003 6:47 pm
Probably. If you could remove the needle, reposition it, and reinstall it, that would work. But it would be trial and error, and you'd need a little puller to safely remove the needle. I think clock/watch repair guys have those little pullers.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Thu Apr 10, 2003 9:02 pm
Many of the factory oil pressure guages are electronic so you need to be sure that the correct feed voltage and a good sending "signal" is getting to the guage.
Most of these guages run off 6 volts, stepped down through a regulator. (voltage limiter) Check the input voltage, 6-7 volts is needed.
The sending unit is a controlled ground, check the resistance there and change sending units if it is out of spec. range.
PostPosted: Fri Apr 11, 2003 11:30 am
The oil gauges are mechanical in the A100's. They have a factory oil
line that runs from the engine to the dash, my line is a NOS line I
just installed. It seems the factory gauge has a small flat tube that
fills with oil and extends slightly when the oil pressure increases. As
the tube extends it pulls the needle to read a higher oil pressure
reading. There is a small link between the tube and the needle. I
was thinking of maybe bending the link to calibrate the gauge?
Has anyone had experience with this?
Mike in WA
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
