It is currently Sat Nov 28, 2026 10:19 am
 Post subject: coil for HEI
PostPosted: Thu Jan 23, 2014 10:46 am
On my 87 D100 I've gutted the stock ECM and will be mounting the HEI module inside. Is there a stock looking canister style coil available to use with the HEI. I know I can use the GM coil/bracket/HEI assembly as SSDan mentioned in the HEI thread but I'd like to keep the engine compartment stock looking.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Thu Jan 23, 2014 11:10 am
2 of our 3 trucks are running the original factory coil.
Rick
PostPosted: Thu Jan 23, 2014 1:23 pm
I was under the impression the coil needed to be a high output coil.
PostPosted: Thu Jan 23, 2014 1:34 pm
Doesn't have to be. You get more benefit if it is, though.
PostPosted: Thu Jan 23, 2014 2:25 pm
I used a pertronix oil filled coil, .6 ohm I think, looks exactly like a stock coil. Cheers
PostPosted: Sat Feb 01, 2014 7:50 pm
I used an Accel 8140 with HEI for years. It was yellow, but a little paint would fix that.
