It is currently Sun Nov 22, 2026 2:30 pm
 Post subject: Plug choice
PostPosted: Sun Feb 02, 2014 5:53 am
I read so much conflicting data on what the best plug might be for my 1986 Hydraulic engine. Right now I am running NGKUR4.
I have read recently NGK ZFR5N is a better plug
Any advice on this? and why make the change?
 Post subject: Nope..
PostPosted: Sun Feb 02, 2014 8:36 am
The stock head for your engine will not take the ZFRN plug, you are stuck with the UR4/UR5 plugs with the tapered seat...If you swap to a pre-1975 head with the drool tubes you can then use the ZRFN plug, but get other issues to work with...
Leave it as is.
