| Fuel Pump Vent Hole https://slantsix.org/forum/viewtopic.php?t=54518 |
| Author: | Greg Ondayko [ Tue Feb 04, 2014 5:38 am ] |
| Post subject: | Fuel Pump Vent Hole |
Hello, Is it possible to block off the vent hole on a stock style lever arm Fuel pump? Mine squirts out all kinds of oil(out of the Vent hole) and I will be putting a vacuum pump on the engine this time around anyway. So I am attempting to seal up all leaks. This would be on the Ruster Race engine. Just curious about it. I dont really want to go to an electric pump if I can avoid it. Greg |
| Author: | hantayo13 [ Tue Feb 04, 2014 6:34 am ] |
replace pump ...should not be leaking anything out vent |
| Author: | Greg Ondayko [ Tue Feb 04, 2014 9:03 am ] |
Quote: replace pump ...should not be leaking anything out vent
I think this is more due to the Oil scrapper and windage tray that I have on that side of the engine.. The Fuel pump itself works fine. I wonder if the scrapper is sending an abnormal amount of oil near the pump arm? Remember this is on a 6500+ rpm race engine, Not on a Street motor. I guess I can try another pump and see what I come up with. it still does not solve the Vacuum Pump / Seal issue. Greg |
| Author: | Doc [ Tue Feb 04, 2014 9:53 am ] |
I add a fitting so I can vent to a higher location or into a "pressure source". (Turbo boost) DD
| Author: | Greg Ondayko [ Tue Feb 04, 2014 10:29 am ] |
Quote: I add a fitting so I can vent to a higher location or into a "pressure source". (Turbo boost)
Excellent, I think that what I was looking to do anyway.. Can I tie it into the Valve cover or some other area that the vacuum pump will be pulling a vacuum on?DD ![]() Greg |
| Author: | Doc [ Tue Feb 04, 2014 10:49 am ] |
You do not want a lot suction on the back-side of the diaphram because the pump will not "pump" fuel. Another option is to make a special fuel pump gasket to block oil access into the pump housing, as much as possible. DD |
| Author: | Greg Ondayko [ Tue Feb 04, 2014 12:41 pm ] |
Quote: You do not want a lot suction on the back-side of the diaphram because the pump will not "pump" fuel.
Again Excellent Considerations.Another option is to make a special fuel pump gasket to block oil access into the pump housing, as much as possible. DD Thanks Doc. Greg |
