| how to remove a power steering pump pulley? https://slantsix.org/forum/viewtopic.php?t=54549 |
| Author: | Mike_64_Valiant [ Fri Feb 07, 2014 9:16 am ] |
| Post subject: | how to remove a power steering pump pulley? |
How do you remove the power steering pump pulley. I have used 3 diffrent pullers and it endend in a trashed pulley. |
| Author: | DadTruck [ Fri Feb 07, 2014 5:08 pm ] |
borrow a power steering pully puller from Autozone |
| Author: | Fopar [ Fri Feb 07, 2014 5:25 pm ] |
There is two types of pulleys one has a nut that holds the pulley on the shaft, the other has a allen socket that holds. Richard |
| Author: | Joshie225 [ Fri Feb 07, 2014 6:08 pm ] |
If it's a Saginaw without the nut then it's a press fit. I used to remove these with a dedicated puller (grips the flange on the hub, not the sheet metal pulley) supplemented with a large C-clamp to keep the two puller jaws from separating and an electric impact wrench. Looked like this: ![]() There are better pullers available than that any more. |
| Author: | dartfordoor [ Fri Jul 25, 2014 5:23 pm ] |
Last weekend on the power nation series, I think either the muscle car edition or engine show, show that exact problem, not using a regular pulley but a special dedicated one that you rent, and they used an cordless impact wrench too. |
