| 1962 Valiant Signet https://slantsix.org/forum/viewtopic.php?t=54569 |
| Author: | crickhollow [ Sun Feb 09, 2014 2:01 am ] |
| Post subject: | 1962 Valiant Signet |
I am restoring a 1962 Valiant Signet and I need some advice on replacing the external door and fender mouldings. The moulding retaining springs/clips were badly rusted (I was able to get 4 good ones) so I have improvised using 3/16" mushroon head roofing bolts. These bolts slide nicely in the moulding and it is easy to attach the washer and nut without the bolt 'turning'. The advice I am after is - does anyone know where I can source the moulding springs/clips and, as I did not remember to mark the mouldings with which door and fender they came from, how can I best determine which moulding strip goes on which door and fender. Thanks, Peter |
| Author: | VDART [ Sun Feb 09, 2014 5:15 am ] |
do you have the arrow points tips for each fender or door? I think your thin metal strips will interchange as they are just straight pieces of stainless-- the tips are the key. mock them up & see which set fits the best on each side, as for the spring clips have you tried R/T specialties? I have two thin strips from a 65-- I'll see if they still have the clips on the back. I'm not sure if the width is the same -- those clips are usually toast when the trim gets removed. Lawrence |
| Author: | crickhollow [ Mon Feb 10, 2014 6:02 pm ] |
Thanks Lawrence. I need some spears, the ones I have are badly pitted. PM me if you have any leads I can follow. Regards, Peter |
