| Carb rebushing https://slantsix.org/forum/viewtopic.php?t=54591 |
| Author: | Sean Mallory [ Tue Feb 11, 2014 1:41 pm ] |
| Post subject: | Carb rebushing |
Is some play acceptable? I ask because I know pretty much nothing about carburetion. The 3 Holley 1945 carbs I have all have a little play, some a touch more than the others, but they all have some. All I have to compare is the throttle body on 5.9 magnum V8, which has zero slop. |
| Author: | Aggressive Ted [ Tue Feb 11, 2014 2:51 pm ] |
Some play can be compensated by your idle mixture adjustment. If your around 2.5 turns out your fine. It is bad when you have to run it 4 turns out. You may want to have the shaft re-bushed at that point. |
| Author: | Sean Mallory [ Tue Feb 11, 2014 4:20 pm ] |
thank you sir when I sprayed brake cleaner into the area, the motor stumbled (yes I know not to do that again!) |
| Author: | WagonsRcool [ Thu Feb 13, 2014 7:36 am ] |
It's chlorinated brake clean that's the seriously nasty stuff. "regular" brake clean is merely explosively flammable. Different types are/are not available in different states. |
| Author: | Sean Mallory [ Thu Feb 13, 2014 10:17 am ] |
Quote: It's chlorinated brake clean that's the seriously nasty stuff. "regular" brake clean is merely explosively flammable. Different types are/are not available in different states.
I went and looked and is was not chlorinated. Dumb luck. :shrug: I am going to see how many turns my idle mixture is at and go from there. I found a local guy to rebush the carb for $30 if I pull the bottom off and take it to him. |
| Author: | Sean Mallory [ Tue Feb 18, 2014 7:03 am ] |
Well Ted it is around 3 turns, maybe a little less. yay What should the idle RPM be in D? say sitting at a stoplight. |
| Author: | Aggressive Ted [ Thu Feb 20, 2014 11:11 am ] |
On my 74 the sticker shows to set it at 750 rpm out of gear which I do...... and the distributor is set at 10 degrees initial.......which is not per the sticker. I recurved my 3755042 distributor. Based on that it shows 19" of vacuum cold. Once warmed up, the tach reads about 650 rpm in gear at a stop light. |
