| "Pop! Clanga clang clang clang" sound from the rea https://slantsix.org/forum/viewtopic.php?t=54599 |
| Author: | 925topher [ Wed Feb 12, 2014 5:04 pm ] |
| Post subject: | "Pop! Clanga clang clang clang" sound from the rea |
Last week I was on the freeway and I heard a loud popping sound, then what sounded like I had a bag with a rock in it stuck to a wheel the sound did not fallow tire speed or engine RPM so I think it is the tranny "Lop lop lop lop". I pulled over and checked under the car, and nothing was out of place. Some days I will make my commute without incident, sometimes I will hear the sound. I avoid the freeway, and I usually only experience the sound when decelerating from over 45 MPH. |
| Author: | bigslant6fan [ Wed Feb 12, 2014 5:32 pm ] |
| Post subject: | . |
My guess would be driveshaft joints,or Trans tailshaft mount |
| Author: | Joshie225 [ Wed Feb 12, 2014 6:26 pm ] |
Pull the rear axle cover and see if you've broken a spider or side gear. |
| Author: | Reed [ Wed Feb 12, 2014 7:19 pm ] |
Quote: Pull the rear axle cover and see if you've broken a spider or side gear.
+1.
| Author: | sandy in BC [ Wed Feb 12, 2014 7:20 pm ] |
Id avoid the freeway.....and for Petes sake...never decelerate. |
| Author: | Sam Powell [ Thu Feb 13, 2014 6:09 am ] |
Quote: Id avoid the freeway.....and for Petes sake...never decelerate.
Sandy, sometimes I forget how profound you can be. Sam |
| Author: | Doc [ Thu Feb 13, 2014 9:03 am ] |
"Doc... it hurts when I do this..."- Doc's answer: Don't do that... Joking aside... Check u-joints first. If the u-joints are OK, then pull the diff. cover. DD |
