| Heat riser solvent ? https://slantsix.org/forum/viewtopic.php?t=54607 |
| Author: | rustytoolss [ Thu Feb 13, 2014 12:24 pm ] |
| Post subject: | Heat riser solvent ? |
Long ago in a galaxy far away ( well 1977) I worked at a Chrysler dealer. At that time we use " mopar heat control valve solvent" to keep the HR working. So its 2014, I'm sure its no longer around. So what is a good replacement ? I think the mopar stuff had graphite in it. There must be something that works well ????????????? |
| Author: | Fopar [ Thu Feb 13, 2014 12:37 pm ] |
You might try lock lube with graphite in it. Richard |
| Author: | curmudgeon [ Thu Feb 13, 2014 1:21 pm ] |
You might try this topic. It is from 2007 but one never knows: http://www.slantsix.org/forum/viewtopic ... ent#132297 |
| Author: | rustytoolss [ Sat Feb 15, 2014 7:26 am ] |
Anyone else ? I'm not the only one with a heat riser these days..am I ? |
| Author: | wpcfan [ Sat Feb 15, 2014 8:05 am ] |
Maybe try Mopar Part 4318039AC |
