Distributor O rings
https://slantsix.org/forum/viewtopic.php?t=54623
Page 1 of 2
Author:  the_shadow [ Fri Feb 14, 2014 6:38 pm ]
Post subject:  Distributor O rings
I have a NOS electronic ignition distributor I got a few years ago from OCPNW. I was going to install it but it looks like it's missing both O rings. I have no idea if the current distributor in my car has O rings or what the condition of them are. I'd like to get new O rings for this distributor before I install it. Does anyone know how I can get ones that fit? Size? Link? Anything helps, thanks!!
Author:  xjarhead [ Fri Feb 14, 2014 7:04 pm ]
Slant Six Dan post the info on here somewhere, not sure where at the moment. I will see if i can find it.
I was able to get them at ace hardware.
Dave
P.S. I thought he posted it on here but i can not find it sorry.
Author:  DusterIdiot [ Fri Feb 14, 2014 7:13 pm ]
Post subject:  It's...
The "donut" gasket that goes between the adjusting plate and block receiver is something like a Fel-Pro 35608, the shaft housing gasket is a square cut O-ring, I think you will have to take it to a real auto parts store and paw through the O-ring container for the correct one.
Author:  the_shadow [ Sat Feb 15, 2014 11:15 am ]
Post subject:  Re: It's...
I just got back from the autoparts store. Fel-Pro 35608 isn't it, too big, and says for water.
The guy behind the counter was bad. I looked thru their O-rings and didn't find anything close.
I'm really at a loss here. Anyone with a distributor out of the car can you measure you O-ring and find it on here?
http://www.amazonsupply.com/o-rings/s/1 ... gw_c_hp_or
This would be really good info for members to know the O-ring and donut gasket size. I can't really start this project without both of them...
Author:  xjarhead [ Sat Feb 15, 2014 12:22 pm ]
I was able to find them at ace hardware in the plumbing aisle.
Or try any place with plumbing.
Dave
Author:  the_shadow [ Sat Feb 15, 2014 12:46 pm ]
Dave
Plumbing O-rings are made out of materials to resist water, not oil. However, if you can measure the O-ring you have I can find ones made out of oil resistant material
Author:  1930 [ Sat Feb 15, 2014 1:17 pm ]
Dave
I can send you one if you like and no-one else is able to help. Youd have to PM me your address. Might be old/worn but at least you would have one to match up.
Let me know
Author:  xjarhead [ Sat Feb 15, 2014 3:18 pm ]
Here if their made from Buna-n they will work for plumbing and oil.
http://www.theoringstore.com/index.php? ... ath=367_23
Dave
Author:  kesteb [ Sat Feb 15, 2014 8:05 pm ]
You don't need them. I have been running my distributor without one for several years now. No leaks, no problems.
Author:  '67 Dart 270 [ Sun Feb 16, 2014 10:44 am ]
Post subject:  o-rings
Mine was old hard and had just a hairline crack and it leaked like crazy. If you're really desperate the engine gasket kits included both of these O-rings. See in the top left corner of this picture...http://www.rockauto.com/catalog/moreinf ... cc=1328734
I'll see if I have an extra set, send me a PM to remind me to look.
Somebody must sell them separately....
bg
Author:  the_shadow [ Sun Feb 16, 2014 12:44 pm ]
Post subject:  Re: o-rings
Let me know
Thanks that's a start, I can at least match that one up to get 1 of the 2 sorted out
Mine was old hard and had just a hairline crack and it leaked like crazy. If you're really desperate theengine gasket kits included both of these O-rings. See in the top left corner of this picture...http://www.rockauto.com/catalog/moreinf ... cc=1328734
bg
Exactly!
If someone could just get me both O-rings, even loan them to me, I'd be happy to do the leg work and match them up via McMaster Carr or something and post the part numbers.
Could any at least supply detailed dimensions for the O gasket that sits right under the distributor?
Author:  SlantSteve [ Sun Feb 16, 2014 2:46 pm ]
I bought one of those distributors from the same supplier. The O ring under the base is an odd size, you've no doubt already worked that out for yourself! :roll: I ended up disassembling the whole distributor for two reasons, firstly it was very stiff to rotate because the old lube had gone bad, and secondly to adjust the advance. While I was at it I found a pair of O rings that were close to what I needed. I ended up trimming the thinner O ring down to the correct OD by placing it over a shaft in a lathe and sanding it until it was thin enough, very fiddly but it worked. The thicker O ring under the base was sorted by using the thickest one I could fine and then building it up with a good silicone sealer, coat the block with oil and then insert the distributor and leave to set. Remove the distributor after silicone is set, trim off excess sealer and you should have a perfectly shaped seal for the area. It worked for me and it doesn't leak. The only correct O rings came in a gasket set, at least over here in Australia. Hope this helps!
Author:  Ed Mullen [ Mon Feb 17, 2014 9:35 am ]
I got mine @ McMaster Carr.
Had to buy like 50 of one and 100 of the other. (or maybe 25 & 50)
Anybody who needs them is welcome to a set for cost of postage.
I'm going to hang on to 6 sets for myself. (by the time I use more than that, they will be dry rotted)
Author:  Rick Covalt [ Mon Feb 17, 2014 12:45 pm ]
PM sent
Author:  Aggressive Ted [ Mon Feb 17, 2014 3:04 pm ]
Post subject:  Distributor "O" rings
PM sent! for a dozen each. I haven't been able to find descent ones either...especially the small square cut "O" ring for the shaft.
Thanks! :D
Page 1 of 2 All times are UTC-08:00
