It is currently Mon Nov 23, 2026 2:19 pm
PostPosted: Tue Nov 26, 2013 8:42 am
So when I bought my duster the PO said he had put in a cam kit that included a mopar purple... 'One size bigger than the smallest they had'. All my research is turning up that mopar only offers 3 cams for the slant six these days. This may have been about 3 years ago. All 3 of mopar's offerings of mechanical purple stick cams for the slant are way too big to put into a car that has probably a 2.76 gear, stock converter, and stock size tires. When it ran I didn't notice any major idle loping. Any idea what this guy might have been talking about? I don't think he had any reason to lie. I might just have to caliper the lift of the valve retainer to find out what's in this girl.
1970 Plymouth Duster, 198 Slant Six, Super Six setup w/ EI conversion
http://www.semisynthetic.net/kill-9/gal ... p?album=34
PostPosted: Tue Nov 26, 2013 10:47 am
Probably this one:
P3690766 SS14-112 268° duration .450" lift, 108° LSA .016"/.020" int/exh lash
I'd say that's a pretty good street cam in a 9:1 motor.
 Post subject: Yep...
PostPosted: Tue Nov 26, 2013 6:27 pm
And a little more rear gear would make it fun. There is a guy here in Salem that built a 10:1 slant with that cam/4-barrel and headers for his A-100 Van...He ended up breaking a couple of A-727's hauling rolls of carpet in it (it was his work van...)...LOL
PostPosted: Tue Nov 26, 2013 7:54 pm
Probably this one:
Yeah I ran the numbers through DD and it seems like it should do pretty well.
PostPosted: Wed Nov 27, 2013 11:14 am
That cam will work well IF you combine it with more compression...
That cam does not work well if you use it in a stock compression engine. (8 to 1 or less is usually where a stock slant's static CR is)
PostPosted: Sun Feb 23, 2014 12:29 am
what compression & carb combination would suit this cam? the cam that pops up most while i'm searching is the comp cams 440/440 solid & is what my friend used. but i want to go a bit faster than him :lol:
