will it work
https://slantsix.org/forum/viewtopic.php?t=5463
Page 1 of 1
Author:  rtdonell1 [ Fri Apr 11, 2003 7:24 pm ]
Post subject:  will it work
slant six , purple shaft 276/490. electronic ignition. orang box. 1 bbl carb stock every thing else. this is the engine that was in the car when I got it. took it apart to do valve job. will this combo work when I get it back togather? I know I could make it better if I had the money but I dont.
Author:  Red [ Fri Apr 11, 2003 8:27 pm ]
Sounds under-carbureted to me...I'd guess that cam's gonna want more gas than a BBS or 1920 can feed it. Would probably perform better with a 390 cfm 2-bbl or 4-bbl. But if you're on a tight budget, start looking for a Super 6 setup...that's probably the cheapest way to go. Check it out:
http://www.slantsix.org/articles/supersix/article.htm
---Red
Author:  87Slant_sickness [ Fri Apr 11, 2003 9:00 pm ]
Thats way under-carb'd, youd need ALTEAST a supersix for that setup to be of any good use.
It'd work, but it would be a realy pain!
Justin
