| What hole for adjusting cable guides? https://slantsix.org/forum/viewtopic.php?t=54631 |
| Author: | Eatkinson [ Sat Feb 15, 2014 4:46 pm ] |
| Post subject: | What hole for adjusting cable guides? |
Finishing the front brakes now. The rear shoes on either side have three holes topside. Of the three, the middle one is blue with a slightly chamfered edge which seems like the hole they intend for the adjusting guide and one end of the secondary return spring. The issue I have is that the spring seems looser there and the lower of those three holes produces a stronger spring tension and a tauter cable. Any issue with using the lowest point instead of the blue middle one for the guide/spring? Don't know why I felt like asking, but I'd rather not F up my new brakes before I've driven. |
| Author: | Joshie225 [ Sat Feb 15, 2014 4:50 pm ] |
The cable needs to be tight enough that the adjuster finger is just below center on the star wheel. |
