Exhaust manifold mods
https://slantsix.org/forum/viewtopic.php?t=54683
Author:  Str8axldart [ Sat Feb 22, 2014 8:19 am ]
Post subject:  Exhaust manifold mods
Is there any horsepower/torque gains by porting a stock exhaust manifold, and hogging out the exhaust dump as large as possible? Or is it a waste of time?
Author:  slantzilla [ Sat Feb 22, 2014 8:24 am ]
There is probably a little there, but mainly a waste of time.
By the time you get done porting it and get it installed it will crack anyway. :cry:
Author:  emsvitil [ Sat Feb 22, 2014 12:30 pm ]
Not worth it if you're paying someone to do it..........
If you have free time, it's not going to hurt; and might help a little....
Author:  Str8axldart [ Sat Feb 22, 2014 3:57 pm ]
Ya I was jus gonna try it out myself. Didn't know if anyone has tried the extrude honing before on a slant.
Author:  slantzilla [ Sun Feb 23, 2014 8:23 am ]
Honestly, extrude honing is normally used when you want a finish that shows no tool marks.
It is pretty much cost prohibitive for the gains made.
If you have a way to get it done cheap it would be interesting to see the results.
Author:  DusterIdiot [ Sun Feb 23, 2014 9:48 am ]
Post subject:  Lol...
You will have to take the heat riser out or ruin it, and getting it back in may be prohibitive...if the car weren't being driven in under 60 degree weather, you'd get the same performance gain by just removing the flap, and plugging the holes with a pair of bolts to free up the cross section from the shaft and plate....
