| Machining question https://slantsix.org/forum/viewtopic.php?t=54737 |
| Author: | joesnow [ Sat Mar 01, 2014 6:24 pm ] |
| Post subject: | Machining question |
I know this is a dumb question, I'm sure I already know the answer, just hoping I'm wrong lol Can you have a slant head machined down without removing the valves and disassembling ? |
| Author: | Damraider [ Sat Mar 01, 2014 11:44 pm ] |
Yep ,just had it done two weeks ago . .085 off . |
| Author: | slantzilla [ Sun Mar 02, 2014 3:38 am ] |
I have had it done too. Make sure to clean it very thoroughly before installing. |
| Author: | 1930 [ Sun Mar 02, 2014 4:03 am ] |
Not a stupid question, thanks for asking |
| Author: | Charrlie_S [ Sun Mar 02, 2014 4:04 am ] |
You will need to remove the lower set of intake/exhaust manifold studs. If you don't, your machinest will be unhappy. His cutter will hit the studs if they are still in the head. |
| Author: | joesnow [ Sun Mar 02, 2014 4:33 pm ] |
Great. Thanks guys. I like the answer, guess I need to go see my local machine shop... |
| Author: | joesnow [ Mon Mar 03, 2014 5:39 pm ] |
Just pulled the head off the slant that came in my '70 duster. Guy said some messed up installing a new timing chain. I'd say so. Five bent push rods... |
| Author: | Rick Covalt [ Mon Mar 03, 2014 7:09 pm ] |
| Post subject: | Push Rods |
If you need some stock push rods let me know. Rick |
| Author: | joesnow [ Mon Mar 03, 2014 7:15 pm ] |
Ok cool... I probably will. Still deciding what I want to do. Waiting to get the car painted. Trying not to spend money until the paint is down lol. Holding off machine work. |
| Author: | jhdeval [ Tue Mar 04, 2014 11:10 am ] |
I have some stock push rods also. I also have a few extra pistons and rods. I am hesitant to get rid of them yet as I have another slant rebuild. Although I have not decided if I am just going to replace it yet. |
| Author: | Doc [ Tue Mar 04, 2014 1:54 pm ] |
Quote: Just pulled the head off the slant that came in my '70 duster. Guy said someone messed up installing a new timing chain. I'd say so. Five bent push rods...
You are well advised to dis-assemble this head and check for bent valves . Valves can also get bent when they hit pistons hard enough to bend the pushrods. DD |
| Author: | xjarhead [ Tue Mar 04, 2014 2:32 pm ] |
Rokauto has pushrods for $1.50 apeice 27.29 with shipping Dave |
| Author: | slantzilla [ Wed Mar 05, 2014 1:26 am ] |
I'd finish the motor before it goes to paint. Don't want to drop that heavy head on new paint. |
| Author: | dartsport76 [ Fri Mar 07, 2014 7:06 pm ] |
| Post subject: | ditto |
what Slantzilla said! I did all the bodywork and paint on my Dart, then had to rebuild the head. Even with special care, the paint still got nicked |
| Author: | joesnow [ Sun Mar 09, 2014 9:02 am ] |
Motor is out... But yeah I don't want scratch new paint |
