| Centerlink query.... https://slantsix.org/forum/viewtopic.php?t=5476 |
| Author: | DusterIdiot [ Sun Apr 13, 2003 11:53 am ] |
| Post subject: | Centerlink query.... |
I was doing some cleanup in my shed, and decided I was going to e-bag a 1974 Dart V-8 centerlink I had laying around. I layed it on top of an OEM Feather Duster centerlink and found the 1974 V-8 version is the same. i then had to check my Feather and my 74 Space Duster, and they both have the same. I thought the /6 version was supposed to have a shallower 'relief' in it, but did the mopar bean counters nix the /6 centerlink from 1974-1976 for cost sake? Here's a quick pic, I couldn't get them to sit on top of each other, so they are a bit skewed, the top one is the V-8 version, the bottom one is a 1976 Feather Duster version... ![]() Anyone have an answer for my trivial curiosity thanks, -D.idiot |
| Author: | Charrlie_S [ Sun Apr 13, 2003 7:08 pm ] |
1964 and 1965 "A" body center links are different V-8 or six. Before 1964 no V-8 available, so only six cyl straight link. I don't know how far back are the same. 1966 "A" body center links are the same, V-8 or six. 1967 and up "A" body center links are longer then the 1966 and earlier links, but are the same V-8 or six. The 64-65 V-8 and all 66 links will interchange for a V-8 installation on 66 and earlier "A" bodies. |
| Author: | DusterIdiot [ Sun Apr 13, 2003 9:56 pm ] |
| Post subject: | Thanks Charlie... |
I always hear the local V-8 guys say that you need to swap the whole front end to get a V-8 into a /6 car....I wonder if they just assume that the centerlink is different too.... cool trivia and info, thanks! -D.Idiot |
| Author: | Charrlie_S [ Mon Apr 14, 2003 6:19 am ] |
It is necessary to swap "K" members, on the 67 and newer "A" bodies, only. The 66 and older "A" bodies use the same "K" member, for the six and V-8. |
| Author: | kesteb [ Mon Apr 14, 2003 12:44 pm ] |
The usage of the V8 centerlink allows you to more easily use the F-body oil pans in the 65-65 A-bodies. There is about an 1" clearance, otherwise the oil pan rests on the centerlink. |
| Author: | DusterIdiot [ Mon Apr 14, 2003 3:28 pm ] |
| Post subject: | Interesting... |
nice to know, thanks kesteb. |
