It is currently Mon Oct 12, 2026 10:10 pm
 Post subject: Bad Vibrations?
PostPosted: Tue Jun 24, 2014 6:05 pm
I just installed the ESPO 6 leaf springs on the 62 Valiant along with several other upgrades. I removed and re-installed the drive line to accommodate a drive line loop.
Now I'm getting vibrations that seem to be coming from the rear. I feel it as much as I hear it. My best description is driving the grooved asphalt on the side of the freeway, but about a 1/4 as intense. It appears between 50 and 60 mph. Bummer...
Where should I start to look? I
Thanks,
Barnaby
These ones go to eleven...
PostPosted: Tue Jun 24, 2014 6:37 pm
6 Pack Dart
Is the 'U-joint seated in the rear end ?
Richard
PostPosted: Tue Jun 24, 2014 6:43 pm
Thanks Richard! I'll check.
Maybe the bad vibrations is karma paying me back for missing the races in Woodburn. Olga and I were bummed that we didn't make it.
B
PostPosted: Thu Jun 26, 2014 7:53 am
Is it worse under acceleration or coasting? Changing the leaf springs could have altered your pinion angle.
Did you have any work done to the driveshaft itself?
Escape Velocity Racing
PostPosted: Thu Jun 26, 2014 8:11 am
Remove rear end of drive shaft from rear yoke at axel and rotate 180 degrees, reinstall.
Did you remove one of the caps from rear u joint during project. One of the needle bearings could have gone missing which will make a "good vibration"...
PostPosted: Thu Jun 26, 2014 8:54 am
I did not notice if acceleration or deceleration changed the intensity of the vibration. I might get to the car today and if nothing is visibly off I will rotate the shaft 180.
There was no work done to the drive shaft and I did not remove the cap.
Thanks guys,
B
PostPosted: Thu Jun 26, 2014 9:22 am
Can you explain this further? I ask because I'm having a similar vibration, albeit at a higher speed, after some driveline modifications. Would this be a good thing to try even if the U-joint is brand new?
PostPosted: Sun Jun 29, 2014 9:18 am
Just an update and a little egg on my face. The drive shaft was not installed correctly. Now it is tight. It is possible that the pinion angle is incorrect, but I'll find out when I road test the car again, hopefully tomorrow.
Thanks for the input.
B
PostPosted: Sun Jun 29, 2014 6:33 pm
I read this somewhere, and after having my drive shaft out for a spot of grease, unknowingly I installed it 180 degrees out, it made more vibration, and flipping it over 180* settled it back down. The grease also helped. A year later I did change out both U joints, but indexed the rear joint to go back as it was.
The tail shaft bushing is a bit worn allowing some vertical motion of front yoke which I suspect allows some vibration that tends to crop up around 62 mph.
PostPosted: Mon Jun 30, 2014 11:40 am
Resolved and no vibrations. Correct installation makes a huge difference!
Thanks for the help,
B
PostPosted: Tue Jul 01, 2014 6:51 am
Huh. I didn't know you could be 180 off. I'll try flipping mine and see if it improves.
Users browsing this forum: DuckDuckGo [Bot] and 13 guests
